kmanilpillai
MJP Converter
hai friends, any one know details about the mjpeg file type. i found that some lg mob uses video in mjpeg format. when iam searched in the net i got only the video encoder. any one know about this video format? is this can used for sending video to mob thru mms.
<< Please refrain from using BLOCK letters when posting in the forum - editing post >>
Edited by Arun
try http://directory.fsf.org/vid/view/mjpeg.html
  anyways, if u dont want results about codecs, just put "MJPEG -codec" in google and search.
cheers
37269[/snapback]
Thanks for ur response Mr. I have the info. about the mjpeg file format. Can u tell me how to create a mjpeg video file. Is any s/w available for that? Can it send to our mob?
I was thinking if ringtones,images could be transferred to our handsets via mss or data cables then why not videos.I tried in lg rd6000 but failed.It was in 3gp format.What is format of videos and trailers in Rworld?
Yes 3GP2 vids(recoreded or saved from another source) can be transferred b/w 6255.
The maximumhowever is 300kb.
I also think it was possible in 7230 the format was MJPEG, I have absolutely no idea what that means.
There should be some way in LG6000 as well
LG handsets do not support 3GP (not sure if 6000 does) it uses EVRC..
Cheers
Ashok
Hi Friends any News of any Bluetooth phone fron LG with Video capture & MP3 or do we still have 2 wait 4 such athing from LD in CDMA :)
What do you mean by EVRC?
42460[/snapback]
Try this ... might help a little
http://www.ncoretech.com/speech/evrc.html
Hello
I have capture 1 small movie from 6230. It is saving in MJPEG format. I want to know whether mpeg & mjpeg both formats are same or different? Can we run some other type of format also on 6230?
If not then any software which we can get freely that can convert video files in mjpeg format?
I don't know if any other type of audio format apart from MP3 we can run on this handset. Anyone has idea for the same?
I tried to download some ringtones from computer to phone through SD card but its not installed. I want to know what kind of formats will run on this handset?
if so, any software for the same? (including animated ringtones?)
if anyone has idea, please tell me
Dear friends,
I also needed mpeg to mjp converter.Can anybody tell where it is available?
:'( I have searched the entire net...MJP files convertor are just not available...also it seems there is no software except the LGSyncAgent which runs .MJP files. Help required.....!!!!
What type of browser is present in LG RD 6230?
Is it WAP(like present in LG 6130 only supports .wbm,.bmp type of images) or supoorts XHTML also
What type of images are enabled in LG RD6230 jBrowser?
hmm... dunno about 6230... but the 2030 one supports wml only and wbmp... some specialised applications also use PNG format.
hi
this is naresh
this is regarding i purchased a new lg6230 handset and i trying to download movie clips from mpeg format but it will support only mjp format to download.So,i searching for the same..............
any body can help me out from this...................
do the needful.................................
EDIT by Vishal Gupta: <Topic Merged!>
Hello Friends, I have an LG 6230, I am not able to play the movie files on my PC because it does not support the *.mjp extenions. So can anybody send me the link from where I can download an MJP Player and also a converter, which can convert *.MJP into other formats,
i am also searching for that type of player & converter but unable to found any..
yeah LG walon ne bhi kya format nikala hai , jo koi bhi nahin chala sakta ,
bhaiya yeah ghatiya phone hai , jisme memory card to diya hai par video chalti nahin aur songs kabhi kabhi chalte hai..
agar aapko kuch mile to bateaga ..
dhanyabaad,,
try the CD that came with 7230. I had that one will have to look for it if I can find out. It played MJP should work with 6230 as well
I was happy to see the link to a software which is a converter and player for MJP files but sorry to state that the link was not found on the network
Can you post it again
Vishal
