jshah83 0 Report post Posted August 8, 2007 Can any one tell how to remove unwanted programs. As there is no option availbe in remove program menu. PPlease reply and also provide resco explorer 2007 registry code cracker if possible Share this post Link to post Share on other sites
Arun 795 Report post Posted August 8, 2007 You can remove all programs that were installed by you, from the "Remove Programs" option under Settings > System You cannot remove those programs that came defaulty installed with the ROM. Share this post Link to post Share on other sites
Dj 25 Report post Posted August 8, 2007 Can any one tell how to remove unwanted programs. As there is no option availbe in remove program menu.PPlease reply and also provide resco explorer 2007 registry code cracker if possible I am assuming you arent aware of of start>settings>uninstall programs however removal of programs inbuilt into the rom is not possible as its not just the exe but also a couple registry entries and the likes (which are un identifiable for all practical purposes) that need be removed. hence stay away strictly. so unless its something u have installed, let it be as is... resco explorer crack is there in the cracks folder in the programs menu. dont use spb mobile shell to navigate... go thru start>programs... however u need to ascertain that the user is set to HP-6700 fro these cracks to work ! Share this post Link to post Share on other sites
