squad1234 0 Report post Posted August 9, 2007 Hi guys, can any1 give me details abt all settings required for WAP access thru minibrowser. I used to use Opera earlier bt it doesnt seem to work anymore. Also, pls tell me if username and password need to be entered in settings. Share this post Link to post Share on other sites
amtrag 20 Report post Posted August 9, 2007 Hi guys,can any1 give me details abt all settings required for WAP access thru minibrowser. I used to use Opera earlier bt it doesnt seem to work anymore. Also, pls tell me if username and password need to be entered in settings. If it was working earlier, then itmeans all your settings are ok..just wait and try again after some time. I also use wap on thru minibrowser on 6235 and 2865...both work without altering any settings Share this post Link to post Share on other sites
raj_raj_in_in 1 Report post Posted August 9, 2007 Hi guys,can any1 give me details abt all settings required for WAP access thru minibrowser. I used to use Opera earlier bt it doesnt seem to work anymore. Also, pls tell me if username and password need to be entered in settings. If it was working earlier, then itmeans all your settings are ok..just wait and try again after some time. I also use wap on thru minibrowser on 6235 and 2865...both work without altering any settings R u in mumbai and ur wap is working???? was working before but since last week it seems to have stop working.... Share this post Link to post Share on other sites
rojajimmy 0 Report post Posted August 13, 2007 Yes I face the same problem WAP has stopped working since last 15 days I m using Nokia 6255 in Ahmedabad I guess reliance saw ur data usage and stopped it Otherwise Opera mini worked damn good on my cell earlier If I encountered any problems I would normally do RESET R MENU and CLEAR MEMORY and it would get solved But NOT NOW Share this post Link to post Share on other sites
situ1962 21 Report post Posted August 15, 2007 Pl try this.switch off the phone,then remove the battery and then reinstall it and try again after switching on the phone.if there any problem other than network,it will most probably get resolved. Share this post Link to post Share on other sites
rojajimmy 0 Report post Posted August 31, 2007 Pl try this.switch off the phone,then remove the battery and then reinstall it and try again after switching on the phone.if there any problem other than network,it will most probably get resolved. Yaar I tried everything Switching off the phone removing the battery and reinstalling it also clear Memory and reset R menu and even called *333 to refresh my R menu Nothing is helping me Share this post Link to post Share on other sites
Kunal Hemrajani 1 Report post Posted August 31, 2007 nuthin wil work.. RCL has blocked it agn.. Share this post Link to post Share on other sites
rojajimmy 0 Report post Posted August 31, 2007 nuthin wil work..RCL has blocked it agn.. Any idea when was it blocked? I mean I have not been able to use since last one and a half month Share this post Link to post Share on other sites
amtrag 20 Report post Posted September 1, 2007 It's still working in 2865...will also check in 6235 and tell. Share this post Link to post Share on other sites
Kunal Hemrajani 1 Report post Posted September 1, 2007 nuthin wil work..RCL has blocked it agn.. Any idea when was it blocked? I mean I have not been able to use since last one and a half month it was workin fyn..but i tink by da end of july or by start of august it stopped workin.. Share this post Link to post Share on other sites
siddharthmenon 0 Report post Posted September 9, 2007 Well I access it every day I think its totally fine .... BTW can we get R-World Membership plan back again ? L1 plan ie ... where you have to pay just Rs25 per month and enjoy ul browsing ... It was discontinued but anyways I can still activate it back ? Share this post Link to post Share on other sites
kams19 0 Report post Posted September 22, 2007 (edited) HI all, Finally WAP working on 6255 handsets.. with the same old settings.. Edited September 29, 2007 by kams19 Share this post Link to post Share on other sites
