copperco2
Triband Nu Plan Need Clarification
In NU plan of triband, if the modem is on till 3am in the morning from the previous day evening without getting switched off at 12am then does it not log this particular session.
kindly get back to me..if you have the similar plan allthe better..
if it does not log such sessions then.. t can be used on the lined of unlimited downloas in the day too..
pl. revert.
MTNL resets your connection and assigns a new ip every 24 hours. So its not possible to be continuously online for more than 24 hours.
forget 24 hrs... connection will dirrupt once every 5-6 hrs.... maybe for few seconds... but hoga
the signal gets disconnected at about 1.30am, it seems if you are coonected from 9pm till the time of disconnection then the log records dont show your log.
would love to share any similar exp.
