write2garg 0 Report post Posted November 5, 2005 hello friends i have ld rd 2030 & facing same problem from last 7 months.from the first day i purchased this phone. actully their is no problem to me but the caller who calls me got echo problem at lasti found it's solution. now i am happy if u have lamination on ur mobile remove it & it will solve all ur problem. thanks. Share this post Link to post Share on other sites
@ksh@T 20 Report post Posted November 5, 2005 i hadnt read the whole posts but only thinnh that i knew is that at times when the end user has/had his phone in cover or got his phone laminated are the phone is in air echoes are there..its experienced in AIRTEL/HUTCH/BSNL and all operators...reliance ka koi lena dena nahin hai Share this post Link to post Share on other sites
RajanPERT 0 Report post Posted November 8, 2005 I read some thing in mobile user guide. When it echoes while connection made with a certain telephone in a certain area. Called "Echo Phenomenon," it occurs if connection volume is too high or caused by special properties (semielectronic telephone exchange) of the machine on the other end. So try to decrease the volume. and bobymots details is also helpful. Thanks and Take Care! Share this post Link to post Share on other sites
@v@nit 3 Report post Posted November 29, 2005 Hi Friends, You all want to solve your echo Problem. To solve your echo problem on your handset just take it out of lamination cover or any other cover your problem will be solved. I also faced this problem and know the answer. Share this post Link to post Share on other sites
raccoon 53 Report post Posted November 29, 2005 (edited) No, in my case just making 2 proper holes for the microphone and speaker solves the problem. I don't think you need to remove the cover/lamination. Edited November 29, 2005 by raccoon Share this post Link to post Share on other sites
