CradleOfDevils
Which Mobile Should I Purchase?
Hello there,
I want to purchase a mobile.My budget is upto 15,000Rs.
I must be able to read books,play movies and songs on it.
Kindly give suggessions.
  copperco2 said:
which technology... CDMA or GSM?
Actually I don't know difference between them(CDMA???GSM???).
Sounds like I have heard these words first time :Decepcionado:
Anyway, anything will work fine.
What do you say about Pocket PC?
Tata N Reliance work on CDMA..
while oder operators lik Hutch,Airtel,Idea,etc run on GSM..
so it depends for wich operator u r subscribin for..
Kunal is right.
both the technologies differ so much that one handset you like may not work for the service provider you want to take connection from...
do some homework..before you buy the handset and we will certainly suggest you good ones in your budget..
Pocket PC is okay but then these are also availbale in both the technology platforms i.e. CDMA and GSM
Which nokia handset with the lowest price can be used for connecting to the net
on a pc through data cable with the help of gprs?
I was connecting to the net on my pc through the data cable using nokia 6080? I have idea gprs for net.
Is it also possible with say nokia 2626, nokia 1600?
I would like to go for GSM. What will be advantages and disadvantages if I chose GSM mobiles?
Can you tell me difference between Java Phones And Symbian phones?
Hope my questions are right :)
  copperco2 said:
Kunal is right.
Technically speaking,I am actually very eager to do homework.Can you recommend me where should I start? I am complete beginner in the field of mobiles :)
If u want to use mobile on reliance or tata go for NOKIA 6275.
If u want to use any other service provider such as airtel, hutch, bpl, idea etc go for nokia SYMBIAN OS.
Java phones have very limited possibilities but very user friendly. whereas symbian OS supports many third party softwares and need to get use to.
But once u get use to it, u wont be able to use any other phones in sense of addictions it gives u.
also check sony ericsson W series phone if ur a first time mobile phone user.
