satrohraj 0 Report post Posted September 7, 2007 I'm using R-connect (115 kbps). (As it is only the option where i live) From the day i started using the R-connect, i've been experiencing problem while disconnecting. When i press disconnect (in R connect window), it R icon, flips and flips and flips.... but the 'disconnect will not change into Connect. When i force it to close, i can't connect. This usually happens, when i leave internet idle. Any help? Share this post Link to post Share on other sites
cmahendra 9 Report post Posted October 22, 2007 actually bhai sahab..reliance ke saath aise hi problem hai hehhehehheh chak de india kar lo duniya mutthi mein relinace ke handsets ke saath jinmein basic to highr level problem hoti hain.. chahe lg nokia classic or any **** for ur problem ...................i don think there is any solution hehhehee reliance sukkssss or cdma sukksss for idle situation always keep on downloading something ...from filehippo.com .... i do it ...in my comp.... ping method did not help me...... use mozilla or opers and keep on downloading latest softwares...from filehippo.com this will give u latest softwares alongwith ur ...u will not face any suh problem.. moreover remember one thing .. reliance itni badi hai to sirf isliye ki usne logon ka bahut paisa mara hai from 501 ke phoen se classic tak... sirf kachra becha hai sitanshu 9958337484 ha ha ha LOLZ you really made me laugh a lot. Most of the things are true and i agree. par itnaa gussa mat karo yaar. REMEMBER RELIANCE BROUGHT THE REVOLUTION CALLED "FREE INCOMING CALLS" FIRST TIME IN INDIA. So thank GOD (and Late Shri Dhirubhai Jee). Ab ise use karna hai ke nahi, depends on us. Now we have lots of options than swearing these companies. Share this post Link to post Share on other sites
