copperco2
Poor Quality Of Ruim- T Sim
Guys.
have you noticed how poor is the quality of RUIM or Tsim..
try just once..
take it out and try inserting it in the slot and you will see tht the corners get scratched and scrapped badly.
I had earlier taken out the RUIM and had to change and again put it in again.. it got bruised..
then today i again took it out to insert the TSim and again it got bruised after inserting it again.. In turn T Sim got scratched in just one use.
how come these poor quality Sim's are sold at 199/- it should be given free....(even then i will not suggest to buy it!! for Free!!!)
Guys.
try just once..
Sims are fine issue is with handset, try inserting any GSM sim in it, result will be same for it.
am nt facing ne sort of problem .. . . .
