@mitJ@in
Classic 703
Price - 900+50 for sim
Product note below
Thanks for the info my dear friend.
no r connect..
well my friends plz any one help me i want cable driver for Classic 703 plz any one help me thx
When it doesnt support Rconnect, what do you need the cable driver for?
Product note below
I didn't see any product note attached........
Am I missing something?
:confuse::confuse:
@kesav
You alone are not missing anything my dear friend. We all are missing the same thing. It seems that the product note attachment has been removed by the topic starter.
@kesav
Bu the way price of this phone is now reduced to 501/- sim card and life time activation Rs. 299/- total charges Rs. 800/-, but better optio is to spend 500 bucks more and buy the LG 3000 .
becoz connect to laptop for charging so need cable driver i have cable but driver need any have plz give thx ...............
There is no need to install drivers for Charging your phone..
Windows or any other OS has nothing to do with the Charging as USB provide 5Volts 500 mA
and you get your handset Charged.
You may do one thing..Cut your Data Cable and disconnect or cut two cables which are for RX TX
other two are + and - which will help you only to charge.
So that OS wont detect your phone.
