adibhapse 0 Report post Posted September 24, 2007 Hi All, Recently I'm having problem with my mobile (LG RD 6130) when I try to connect it to PC using USB data cable. When I install the drivers for it, then it was working fine for some time, and when I try to reconnect it, it was giving me a message saying that the device has malfunctioned and etc. I don't know whether the problem is with the handset or PC or the cable. But if it always gives me the same message, then it is understandable, but it does this sometimes I mean sometimes it works. So what could be the permanent solution? Or I should not trust LG devices. This is really frustrating? Isn't it? Also there is no proper help from Relialce as well. Regards, Adi Share this post Link to post Share on other sites
