ubhat 0 Report post Posted October 2, 2007 can anybody tell whether the datacables being advertised on rediff shopping by GNET suitable for the rd 5340 phone.namely RELIANCE MAXIMA,RELIANCE HQ,RELIANCE ATLAS datacables.are they reliable and what is the difference between the 3 models.also where can i get the CHEETAH brand of cables made by sapphire india? please help Share this post Link to post Share on other sites
kshah 452 Report post Posted October 2, 2007 Ifyou want I have one USB cable original for 500 bucks plus 100 courier Share this post Link to post Share on other sites
kshah 452 Report post Posted October 6, 2007 It has charger port where you can plug in your charger. Share this post Link to post Share on other sites
prakashkadam 1 Report post Posted October 17, 2007 first thing is that cables sold on ebay rediff and all that **** are local.........original cable is for 1200.. reliance rconnect handsets are having only two models of cable one that fits in 2030 and other for 2230or 7130 check out reliance website for this... I have one cable for 2030 and other one for 6130, can i use either of this for 5340? Share this post Link to post Share on other sites
Honest 836 Report post Posted October 17, 2007 ^^^ I think you can use the data cable of 6130 with 5340. But I'm not 100% sure. Please confirm from other sources also. Regards. Share this post Link to post Share on other sites
prakashkadam 1 Report post Posted October 18, 2007 ^^^I think you can use the data cable of 6130 with 5340. But I'm not 100% sure. Please confirm from other sources also. Regards. if anybody has used it pl advise. Share this post Link to post Share on other sites
