rakeshg59
R Surf In 3100
Hey all.... i recently brought a Lg RD 3100.... and i wanted to know if there is any way i can get r surf working on it... cause its having a brew browser so i dont know why r surf doesnt work in it.... i used to have a Rd 2030 an r surf worked perfectly well in it... but in 3100 it doesnt even display it in r world... if any1 knows how i can get it started or can i install a java browser in 3100? pls reply
I am planning to buy LG RD 3100. Your feedback on that handset will be invaluable.
well, the handsets display only those options which the software installed it it cansuccessfully run.
if you do not see the option then may be the aplication is not supposed to run on the handset.
btw are you aware of any handset which does not support Rconnect and still has Rsurf?
do let me know....
