Utsav 0 Report post Posted June 22, 2004 I've heard that if you wish to make your Handset's battery live long, you should let the battery be discharged completely before you put it on to the charger tray. Is it a myth or truth? Share this post Link to post Share on other sites
Code 0 Report post Posted June 22, 2004 I think it is mainly for older Ni-Mh batteries Share this post Link to post Share on other sites
harsh 1 Report post Posted June 24, 2004 as per my experience, if you charge the battery after it totally discharges, it lasts long. but if you charge it from the half way, it comparatively gives you less time. try it and post your experience. Share this post Link to post Share on other sites
niket 0 Report post Posted June 24, 2004 Anyway.. It is good habit to charge ur phone after fully discharge.. but practilly it is not possible every time. Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted June 27, 2004 but it is good for the battery's life if it is dischared completely once a while like every 2 weeks and then charged again. Share this post Link to post Share on other sites
emmi 3 Report post Posted June 27, 2004 but it is good for the battery's life if it is dischared completely once a while like every 2 weeksand then charged again. Why is it so can u explain the reason behind it? Share this post Link to post Share on other sites
raccoon 53 Report post Posted August 8, 2004 The reason is obvious - it has to do with the phenomenon of "memory" in the battery. Those who are really intrested could look up some good literature on it... However Li-Ion batterys are not known to suffer from it. So it should not make a difference. In my case, I try to let my battery discharge completely (or almost compeltely) before recharging. Somehow it does seem to make a positive difference! Strange... Share this post Link to post Share on other sites
Utsav 0 Report post Posted November 12, 2004 It is a strange phenomenon that occurs in Ni-Cd battery. I dunno about Li-ion batts. In No-Cd, the battery starts charging from there where it is left with charge. Full Charge------: 123456789012345678901234567890 Aft Discharge----: 123456789012 Next Recharge---: ************345678901234567890 Next discharge---: ----------------34 Next Recharge---: **************5678901234567890 After a certain repetitions, the "*" zone becomes DEAD! Share this post Link to post Share on other sites
Gandalf 0 Report post Posted November 13, 2004 I know for sure that for Li-ion batteries the life of the battery is measured in number of recharge cycles. So lets say a battery has a life of 100 charges. Now this 100 charges means 100 complete charges, ie. 1 charge = complete depletion to full charge. Therefore if you charge when the battery has discharged only half way, you will prolong the life of the battery because you have only consumed .5 charge, and you have 99.5 charges left, as opposed to if you had let it completely discharge and thefore would have consumed 1 full charge, leaving 99 charges. Gandalf It is a strange phenomenon that occurs in Ni-Cd battery. I dunno about Li-ion batts. In No-Cd, the battery starts charging from there where it is left with charge.Full Charge------: 123456789012345678901234567890 Aft Discharge----: 123456789012 Next Recharge---: ************345678901234567890 Next discharge---: ----------------34 Next Recharge---: **************5678901234567890 After a certain repetitions, the "*" zone becomes DEAD! 18874[/snapback] Share this post Link to post Share on other sites
karpar 1 Report post Posted November 13, 2004 Its all the same then, because when you charge it again after it has discharged 50%, it gets charged ONLY 50%! You see...? You won't be PROLONGING the life of the battery that way! Share this post Link to post Share on other sites
linuxguy 0 Report post Posted November 14, 2004 The effect is called "Memory Effect". My new digitcal camera has Ni-Mh batteries and the manual warns against this "Memory Effect". It is 100% safe to charge Ni-Cd/Li-ion batteries as often as you want. Ni-Cd/Li-ion batteries simply dont have the "memory effect". Share this post Link to post Share on other sites
Utsav 0 Report post Posted November 14, 2004 But I've heard this abt Ni-Cd batts from my Sir (M.Sc. physics). Share this post Link to post Share on other sites
Utsav 0 Report post Posted May 1, 2005 Conclusion guys, Memory Effect is applicable for Ni-Cd batteries only, not for NiMH or Li-ion batta. So... Don't worry behappy Share this post Link to post Share on other sites
