nilesh_ku 0 Report post Posted November 1, 2007 Dear Friend, I would like to buy cheapest model just for using R-Connect, can anyone suggest a handset. Thanks Nilesh Share this post Link to post Share on other sites
Harshad 1 Report post Posted November 5, 2007 (edited) get a second hand lg 2130 moonlight phone ... u'll get it around 500 bucks ! Edited November 5, 2007 by Harshad Share this post Link to post Share on other sites
Honest 836 Report post Posted November 6, 2007 ^^^ @nilesh Yes my dear friend, as Harshad has stated above you can go for second hand mobile if you want to use it for R-connect only. And do remember to purchase the second hand handset only with data cable otherwise you have to shellout some extra bucks to buy a new data cable, which makes the deal costly. So try to search the used phones only with data cable. Regards. Share this post Link to post Share on other sites
copperco2 24 Report post Posted November 7, 2007 ditto. for that matter even lg 2030 will be available for about Rs.500 with data cable... yes. as 'honest' has said if you do not get the data cable with the handset then the datacable is available for Rs.300+ for your use.... Share this post Link to post Share on other sites
