RBJ
Use Motorola Q Usa Into India
Guys,
Do you have any idea if I can use my Sprint USA Motorola Q in India ?? I would appreciate if you guys can throw some light on this topic. I am planning to travel to India and was wondering if I can use my Q in India or not. Its basically CDMA.
If it's uim enabled handset,just insert a reliance or tata sim and it will work.otherwise you have to hack it to make it fit to use here.this is what i know.ne course i may be wrong.
its not UIM..
anyone sucesfuly done it ?
Possibly yes. One has to try.
