taran.rbk
Help Needed ( Com )
hey guyz , im using reliance LSP 340-E , i hav bought its usb internet cable for my laptop because there no other port.
When i install the ports , it comes that " ur computer has no COM 1 and COM 2 " . my laptop has three usb ports -COM7,COM8 and COM9. when i try to install on these com , it says "there is no phone connected".
PLZ tell me wat to do ?? :confuse:
iam not understod how you have connected
there is no usb cable for such 340 phone
only com is available
and
You buy one USB to com converter better if you go for BAFO or TECHCOM
which is less than 350 bucks
And nw install their drivers before connecting to the LAPTOP
Now connect the data cable(USB to COM) the lap will configure by own
You just need to press positive reply YES ACCEPT and so on
After that you connect your LSP 340 phone with your Lap with the data cable you have for that
And if that was a TATA phone you go to command settings and modem settings configure the EXTRA command line in the extra setting as AT+CRM=1
if it was a reliance you can find dialer on rilweb which was already posted you can check some of my
and now create a dialer
FOR TATA username will be INTERNET
passwd also the same
and for reliance that will be your phone number
That will do
if still any more problem
go to device manager and open the properties of your new comport that was created adjust the parity settings to other and test now " work for all the three available options
one will do
BEST OF LUCK
@taran
My dear friend, in Reliance no USB data cable is available for this phone model. Which data cable did you purchased.
Actually there is a same model in TATA also. You can purchase the USB data cable from TATA gallery (available only in TATA HUBS) which will cost you nearly Rs.600/- and then use it with your phone on Reliane. I'm using the same.
hey there is no such com port in my laptop .it has only 3 usb, 1 modem,1hdm port.
I know
I have suggested to buy a usb to com converter data cable
you read the subject first then enquire from the market
BF-810
in http://www.bafo.com/menu-support_part03.asp
watch the item and buy one for your laptop
and then go to some tata hunb
ask them for LG LSP 340 E serial data cable that costs you only 150 bucks
Best regards
Praveen.Valluri
friends , i had gone to reliance web world also , they r usb internet cable for 550 .
can any one give its driver and software for it ? bcoz i had buyed only cable
previously i was using software which i got with com .
