Amir.php 0 Report post Posted November 27, 2007 i have recently upgrade my system to murcury(intel 82945 chipset)moherboard,dual core processor,1gb ram etc. after installing the usb cable and my LG RD 2130 modem when i tried to connect my system is Hang up.i try again but system hang again and again. while on my old configuratin i have been successfully use internet using this setting as well as this cable and modem. My os is xp professional. the same problem also srises on vista. please give me some suggetions. please tell me running r connect on vista Share this post Link to post Share on other sites
praveen.valluri 0 Report post Posted November 27, 2007 try for dialer download from Rcom.com chosing vista os and ur phone model then run the dialer setup on oyur syss if that was availble manually we can not do that untill modem response get tested thru vista and the command lines are known for extra setting Share this post Link to post Share on other sites
Honest 836 Report post Posted November 27, 2007 ^^^ @praveen My dear friend, actually Vista drivers for phones are still not available with Reliance website. It is available only for Data Cards. @amir My dear friend, try installing and running the same with compatibility mode of Windows XP SP2. If still problem persists, than check your data cable. Regards. Share this post Link to post Share on other sites
