Vishal Gupta
"prl" Directory
Hi guys
In LG-RD2030 file system, there is a directory "prl"
i want to know what is the use of this directory?
recently i mentioned that accidentaly i deleted this directory in my mobile,
then my mobile denied to start.
then LG service centre guy replaced the PCB card of my mobile and the mobile is working fine now.
so tell me what "prl" directory stands for?
one more thing, before this problem (before i deleted "prl" directory) whenever i see s/w version of my mobile by pressing <Menu>+4+7, i see:
S/W: RD203F15
PRL: 1
but now (after replacing PCB card), it shows:
S/W: RD203F15
PRL: 2
why?
please meri samasya ka nivaran karo.
PRL 2 Means
You Cant listen ringtones from your handsfree  you can only listen in your speaker
ok.. tht means its that updated version of S/w ?
It might be showing the PRL file version loaded in your phone..
I dont think it does anything bad :D
The PRL is ->
Preferred Roaming List. A list of SID's kept inside a phone to permit roaming on other wireless networks. A service provider may set up roaming agreements with other service providers in different geographic regions and the PRL will try to locate one of these service providers' networks first when the home service provider is unavailable. PRL's do change so it's a good idea to ask for a PRL upgrade every 6 months or so if you do a lot of roaming outside your home service area.
www.geckobeach.com/cellular/intro/glossary.htm
it's the part of the phone's operating system.
not exactly the operating system, but a part of the carrier signal infomrmation.
so if i never went outside of india
then why it is changed?
S/W: RD203F15
PRL: 2
why 2 instead of 1?
S/W: RD203F15
PRL: 2
why 2 instead of 1?
i beleive that there are two copies of the PRL.
PRL 1 and PRL 2
one of them acts as a backup
static i think ur right
but i want to know if my phone was displaying PRL: 1
then why it is now displaying PRL: 2
i did not go Gaziabad since last two months
then why?
well, it's showing PRL 2 because the phone is currently using PRL 2 for current operation.
then can i change it to previous condition
i mean
PRL: 1
is yes then how?
hmmm
no idea about that,
but why are u bothered as long as the phone is working fine with any one of the PRL's
look, the PRL's do not have to do anything with you'r roming habits.
it's just an identifier for the service provider (reliance)
dont bother
thanx static
now i am satisfied
if i'll get any problem then
RIMweb hai na :D
prolly U can change - if u were to overwrite with the older one U backed up ...
but again since they (LG) replaced ur board they might have changed some other info too and Ur older PRL may not work ..
who knows phone may not boot up too ??
May be ppl who cloned RIM can answer to U for sure :D
And emmi, u need not tell BORED whts cloning!
:lol:
I was trying a brilliant/??stupidest -_- idea - sending sms to a email address B)
Goto the sms directory using Bitpim..
In a sms U recieved from a GSM - You can edit the sender's number with a hex editor and replace it with the email address. Close bitpim.
Now goto the mobile SMS menu Openmessage. Select the option reply. Type the New message of Ur choice and send it ...
SMS/Mail is delivered to the destination email box :clap:
The obvious limitation is the length of the email ID and most of the ID's can't be used.
Now I am not a php/perl expert - but if one has his own mail server I thnk he/she can write a script to check for a authenicode info at the end of the SMS'mail and if present then send mail with the SMS contents to the email address which is present at the end of the SMS ... So you can mail is available anywhere even if R-World goes paid and U don't wnat to use it, and once setup it can be very fast and simple as any SMS B)
Try all this at Ur own risk..
But U SHOULD KNOW THE LIMITATION...
Never exceed the phone number space in the SMS (Don't use INSERT in the hex Editor). I did and I think now lost my board as it never booted up again
I think the cause is that the oversized email address string corrupted the files where recent numbers are stored which is subject to a lot of "fraud checking" :ph34r::ph34r::(:help:
Wish me Good luck...
