Vishal Gupta 4 Report post Posted June 25, 2004 hi guys! in my recent posts i mentioned that my mobile was not starting because i deleted "prl" directory. LG service center guy told me that PCB card should be changed. i told him that flashing the mobile can solve the problem. but he said that mobile is not starting so computer is not detecting the mobile, therefore falshing could not be done. and yesterday he changed the card and my mobile is working fine now. i want to if he can not flash the mobile because of starting problem, then how they install s/w first time when the mobile set is manufactured. because when mobile set is manufacyred there is no s/w in mobile and therefore mobile will not start, then how they install s/w? please tell me. Share this post Link to post Share on other sites
net_secrets 1 Report post Posted June 25, 2004 Yes Vishal, i was just thinking to post the same thing here , i want to know how to flash RD2030. Also i want to know why there is a connector provided on back side of phone bellow battery. ( behind sticker inside) Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted June 26, 2004 Its true, until the phone starts, the s/w they use for flashing wont be able to detect the phone. Btw, Those guys dont install the s/w first time The set comes with the loaded s/w from the company Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted June 27, 2004 Its true, until the phone starts, the s/w they use for flashing wont be able to detect the phone. Btw, Those guys dont install the s/w first time The set comes with the loaded s/w from the company well, let me elaborate a bit. it's just like ashok says, that the software comes pre-loaded. but then how is it pre loaded?? isnt it? well, therer's this flash/EEPROM/EPROM/ROM on the phone's PCB. this is a chip which is (generally) mounted in a socket. this chip is programed using a rom programer and is then put into the socket in the phone's PCB. Share this post Link to post Share on other sites
