manivannan 0 Report post Posted December 6, 2007 I am using a 5130 for past 3 years. Till now I had no trouble with the handset. But now there is a serious problem. The battery charge gets drained in just one call. If I dont make any call then the battery charge remains for a few hours. When I put it on charger it says "Charging complete" in few minutes but the problem repeats. I changed the battery but no use. Has anyone faced this problem before? How much would it cost to fix this? Thanks, mani Share this post Link to post Share on other sites
kshah 452 Report post Posted December 7, 2007 Software is corrupted / hardware problem. In most cases no one will be able to resolve this. Share this post Link to post Share on other sites
Honest 836 Report post Posted December 7, 2007 ^^^ @manivannan My dear friend, you can try the authorised LG service centre for the solution of this problem. I think its a hardware problem. Regards. Share this post Link to post Share on other sites
manivannan 0 Report post Posted December 17, 2007 Update: I got my phone and charger checked in LG Service centre; they said everything is fine, but the panel needs to be changed because there is some loose contact caused by the old panel. The panel replacement will cost Rs.1125. I have decided to leave Reliance after 3 years and join the GSM world. Share this post Link to post Share on other sites
