sumesh 0 Report post Posted December 7, 2007 i bought a usb cable to connect to the lsp 340e phone and connected to rs232c port,but the computer did not recognize the usb cable what i do i installed many softwares to detect it but it does not works Share this post Link to post Share on other sites
Honest 836 Report post Posted December 7, 2007 ^^^ Check your cable my dear friend. You can buy the usb cable for this handset from TATA hub. Actually most serial to usb converter cables does not work on this handset. Only the one available with TATA is guaranteed to work with this particular handset. You will get this cable only at TATA HUBS. The price of this cable is nearly Rs.650/- approximately at tata hubs. Regards. Share this post Link to post Share on other sites
spknair 1 Report post Posted December 10, 2007 Hai sumapottans !!!!!!!!!!!!!!!!!!!! you also here???????????????????????? welcome to our world !!!!!!!!!!!! of rimwebians !!1 Hi Hi Hi Share this post Link to post Share on other sites
spknair 1 Report post Posted December 10, 2007 i bought a usb cable to connect to the lsp 340e phone and connected to rs232c port,but the computer did not recognize the usb cable what i do i installed many softwares to detect it but it does not works Dear Honest, Sumesh had bought LSP340E from reliance to use netconnect on his lap please give him guidelines to access rconnect We had downloaded rconnect software from relianceinfo for LSP340E, but it has only serial port interface How can use it with laptop can we use with usb-serial converter? Please specify Share this post Link to post Share on other sites
Honest 836 Report post Posted December 10, 2007 ^^^ @spknair My dear friend, usb2serial converter probably doesn't work with your lsp340e. The only substitute to use your handset with a usb interface is to purchase the same handset's usb data cable from Tata hubs. As Tata too was having this lsp340e model with them and they introduced the usb data cable for the same. But reliance doesn't introduced any usb data cable for this handset. No other substitute is their apart from buying a usb data cable from tata hub. Or else you can swap the handset with a new handset by paying Rs.1000/- as swapping charges to Reliance. All other FWP's are compatible with usb interface. Regards. Share this post Link to post Share on other sites
sumesh 0 Report post Posted December 12, 2007 thank you very much rimguru for your advice,i am going to buy the cable from tata hub,take care bye Share this post Link to post Share on other sites
Honest 836 Report post Posted December 12, 2007 ^^^ @sumesh You are always welcome buddy. Regards. Share this post Link to post Share on other sites
