yameepri
Zte Usb Modem Connection Speed
I am using R- Netconnect. The speed is very low. are all the ones using this facing the same problem. when i call customer care i am not getting proper response. Please help...
@Meenapriya
My dear friend try to ping your connection. You can find out about the PING method in the forum by searching. This will help you out.
