coolrajiv
Samsung Launches Midrange Music Mobile
Source - http://www.tech2.com/india/news/multimedia...-mobile/23544/0
Slider mobile king Samsung, has launched yet another music mobile directed at the midrange consumer. The Samsung F250 is equipped with a 2-inch TFT display with a resolution of 128 x 160 pixels and 65k colors.
The F250 has a 1.3 megapixel camera and direct music access keys. It also comes with an integrated FM radio and supports Bluetooth v2.0 with A2DP compatibility and EDGE. It has only 20MB of internal memory but supports microSD cards up to 2GB. This slim slider has dimensions of 94 x 46 x 17.5 mm and weighs in at just 96g.
The Samsung F250 should be out sometime next year and will be priced at approximately Rs. 10,410 (180 EUR).
at this price it is a bit expensive handset. With better features Nokia N70 is available at same price.
This handset should be priced around 7k
Yes my dear friends, this handset seems to be little bit costly. Anywhere aroung Rs.7500/- will be justified with this type of handset.
