mr.sanjeev 2 Report post Posted December 14, 2007 Guys, Here is another problem and its solution in iPhone. I was confused with my problem as there was no solution for it with me. My problem was when i was trying to make calls from my iPhone and after dialing any number, it immediately takes me to Call Ended. I was able to receive calls, sms and send sms but out going was not possible. Then, i started search on this issue found some solutions Reset my phone - no result dialed ##004# to deactivate all forwarding - no result Changed few different sim card - no result set "Show my caller ID" to "OFF" and "ON" - no result then i found solution on following path http://modmyifone.com/forums/showthread.php?t=8688 1) Settings > General > Date and Time > (Here, switch off "Set Automatically" and manually select your hometown). Then manually set the date and time. And now my phone is working normally Great!!! Share this post Link to post Share on other sites
