csureshbabu 0 Report post Posted December 18, 2007 Hello, I am using LG 5130 for almost 2 yrs . The calls gets DROPPED and the signal strengh keeps varying. I am not ale to receive calls inside my office building on my phone but, others using NOKIA 2865 , LG 6275 & LG 2030 are able to receive calls. My LG 5130 does not pick up the signal and the number of signal pins are nil. Is there a way to increase the sensitivity of my phone? Is changing the phone the only solution? How is the sensitivity of LG 6600? Can I use the LG 5130 data cable with 6600?I use my phone extensively for both voice and data(NET). Pls suggest. Share this post Link to post Share on other sites
Honest 836 Report post Posted December 18, 2007 ^^^ My dear friend, in my suggestion first of all you must take your handset to your nearest LG service centre. Then only plan for the new handset. As LG 5130 is a good handset. If their is minor problem then sure it will be resolved at a minimum charges. And their is no way to improve the signal strength. As you told that other people at your office are able to make and receive calls through their respective handsets. Than surely it seems that their's a problem with your handset. Service centre guys will help you better. Regards. Share this post Link to post Share on other sites
