Dj
My Dad's Nk 6235 Says Not Charging When Connected For Charging
guide me what needs be done... my mobile guy ahs tested the hardware and says nothing is wrong with it... power ic, connector tracks... everything seems to be working just fine...
Either battery is faulty or charger is faulty or wrong battery model. If u put BR serie battery instead of BL serie than this can happen
using BL-6C, the specified battery; cahrger is working as is the battery when being charged in another phone...
somtimes 'not charging' is showed when theres improper voltage coming out of the charger ( i.e. either charger is faulty or the voltage in your house is coming low or high)
just check it at some other place instead your house or wherever you are using it
tried but doesnt work with anyother charger anywhere else either... strange but true...
Get that small charger pin in charger hole changed, repair guy should charge not more than 50 bucks.
If only u don't have warranty left and you dead sure that u using original charger.
lemme try this Sadik...
