taliyan 0 Report post Posted December 30, 2007 I want to know the cheapest mobile color/BW in which I can use r-connect under life time prepaid scheme. Does lifetime prepaid has r-connect facility? Share this post Link to post Share on other sites
supernova 47 Report post Posted December 30, 2007 r connect facility is set dependent . any plan in pre or post can use r connect if mobile supports . Share this post Link to post Share on other sites
Honest 836 Report post Posted December 30, 2007 ^^^ @taliyan My dear friend, if your main purpose is to use only rconnect through your mobile then their is no need to purchase the new handset. You can search for the old handsets easily available in the markets at approximately 400-500 only. Regards. Share this post Link to post Share on other sites
srikanth_kv 3 Report post Posted December 31, 2007 where do u buy a second hand handset ? how to be sure that it is not a stolen piece but genuinely exchanged one it hurts ones consciousness to buy a stolen piece Share this post Link to post Share on other sites
summermax 0 Report post Posted December 31, 2007 buy from a trusted dealer kk.. or u can buy it from ebay....... 2030 2130 2230 5130 5340 only these sets can give u gud internet speeed....these are reliance lg cdma handsets i dont have knowledge of nokia samsung...etc ask others abt these handsets... Share this post Link to post Share on other sites
Honest 836 Report post Posted December 31, 2007 where do u buy a second hand handset ? how to be sure that it is not a stolen piece but genuinely exchanged one @srikanth My dear friend, all second hand mobiles which are available in the markets are not stolen mobiles. I do agree that some of them can be. But this does not mean one should not buy a second hand mobile. One must by the second hand stuff from the reputed shops or known persons only. I don't think their is any harm in purhcasing a second hand mobile. Regards. Share this post Link to post Share on other sites
praveen.valluri 0 Report post Posted January 1, 2008 Yes my dear We have had so many RIM mobiles put up in the shops And we may not know whether if someone would claim the same if i buy it and then But we do have so many RUIM based cdma phones available these days And that would never matter either if the owner was a defauly payee or whatever it was hmm but never go for an used number in seconds ,for the reason of privacy,, And one more thing whenever you want to sell out the non-ruim based model just cancel the connection first otherwise your number would take a chance to face crime or fake callers Share this post Link to post Share on other sites
