Omar3thman 0 Report post Posted January 6, 2008 Hello dears, I’m using TATA Indicom Plug2Surf and suffering a very slow speed!!!, sometimes its as slow as 28.8 kbps connection and maybe slower!!! For that I’m thinking to shift to Reliance Plug2Surf Shall I go ahead? Or Reliance Plug2Surf have the same problem? Greeting p.n Location: New Sangvai, Pune Share this post Link to post Share on other sites
Arun 795 Report post Posted January 6, 2008 do you get good signal for TATA Indicom in your are ? how many signal bars does it show when the speed is slow ? If the signal strength is better for Reliance in the same area, then you might consider switching. Share this post Link to post Share on other sites
Omar3thman 0 Report post Posted January 6, 2008 (edited) Thank you dear Arun for your prompt reply The signal for TATA Indicom in my area is strong and the indicator bars shows full (5 bars) even though lot of times the speed is very slow What make me angry is that the connection speed shows 230.4 kbps while it is actually not exceed – in the best speed – 56 kbps! Assuming the same signal strength for both TATA Indicom and Reliance Is Reliance scores better actual speed or not? Thanks and best regards Edited January 6, 2008 by Omar3thman Share this post Link to post Share on other sites
