jatin_the_great2003
Sms Storage In Memory Card For Nokia 6275
Hey Guyz,
As we all know tat our Nokia 6275 supports very less sms storage... :Equivocado:
So is there any way to store the sms on the memory card...???
Whereas there are only 3 option for sms storage : Phone, UIM, UIM/Phone if no memory.... :NOTriste:
These options hv nothing to do with storage in memoeyr card...
So Guyz any help for the storage purpose..??? :winko:
No solution to this problem till now.. except that u can occationally transfer ur messages to PC or next option if you are a DAPO user then u can send all ur messages to some other gsm set for storage. :D
@jatin
There seems to be no option available for this problem my dear friend.
The world seem to be increasingly getting brain dead. at least thats where these new phones are looking like. 6275 is definitely a phone created by brain dead people for a brain dead world which is going bonkers about it. how can u have a phone which has something like 21mb phone memory where u have to save ur messages and contacts. i'm not able to store 1/3 of my contacts on this stupid phone while the phone allows a memory card access where u can have watch few GBs of video and music! this is really the height. and i think the phone makers and users should start accepting that the phone is used to make calls to an unlimited number of people in the phone book!
@Mr_Flop, can you please elaborate on the above point? I am not able to transfer the messages to PC.
How can we transfer messages to the PC Please help
I'd like to know that too!!!
Anyone???
backingup sms to pc:-
Use SMS Caster
OR
Open Hyperterminal in M$Windows by typing in "hypertrm" in Run command.
Select the COM port where the nokia phone is connected(u will get the port from modem properties in device manager)
In the hyperterminal connection, tpye..
ATE1...enter..will give u ok..
AT..enter..will give u ok..
AT+CMGL=1...enter
AT+CMGL...enter
Just copy the text and save
Edited by theking
Use SMS Caster
OR
AT+CMGL=1...enter
AT+CMGL...enter
ALSO U SAVE MANY SMS IN U R MEMORY CARD AND SEND ALSO
SAVE SOME SMS IN NOTEPADE ON PC
THAN TRANSFER THIS NOTEPADES TO U R MOBILE MEMORY CARD
U WANT TO SENT NOTEPADE SMS SO
OPEN NOTEPADE IN MOBILE MEMORY CARD --OPTION--COPY TO NOTES
NOW THIS NOTEPADE SMS SHOW IN
ORGANISER--NOTES
THAN GO YOUR SMS --OPTION ---SEND NOTE--SEND AS MESSAGE---TEXT MESSAGE
THAN DELETE SOME NOTE: WORD IN START OF U R SMS
THAN SEND TO ANY NO......
ZINGALALA
SMS CASTER HAS DONE THE TRICK FOR ME
IM USING NOKIA 6275 AND I CUD BACK UP ALL MY MESSG TO MY PC IN EXCEL SHEET
ALL THANKS TO U DEAR
THANKS & KEEP PROVIDING SUCH USEFUL INFORMATION IN FUTURE TOO
THANKS AND BYE TC
THANKS AND BYE TC
HI I AM NEW HERE AND REALLY NEED HELP IN USING SMSCASTER. I AM USING FULL VERSION OF SMSCASTER E-MARKETER CDMA 2.8 AND NOKIA 6275I PHONE. WHEN I CONNECT MY PHONE USING USB DATACABLE NOKIA PC SUITE WORKS ABSOLUTELY FINE BUT SMSCASTER DO NOT DETECT MY PHONE. I HOPE SO THERE IS PROBLEM IN SETTING OF COM PORTS. EVEN CLOSING NOKIA PC SUITE DO NOT SOLVE THE PROBLEM. PLZ HELP ME I NEED UR HELP.
DATA CONNECTIVITY MODE I USE IS : NOKIA MODE
REALLY THANX 4 UR HELP. :help:
I HAVE ATTACHED SCREENSHOT OF SMSCASTER FOR FURTHER REFERENCE.
just remove d data cable from pc and restart d computer then again connect d phone to d pc and restart d smscaster.if its not detected then select d port & press update or update all in smscaster.
hope it will help.
Great !! I have connected my phone through Bluetooth & backed up all messages.
hope it will help.
thanx 4 ur help but it still does not solve the problem i am still unable to connect my phone 6275 to smscaster.
plz help any further suggestions !
:NOTriste:
can u tell me in detail how to make a bluetooth connection with smscaster cdma.
:sos:
Is SMS Caster can only be used for backing up the sms or can it send also.
I am using 6275. Please reply
@Vishal
Sent SMS also
Plz tell me how to connect 6275 va bluetooth.
can u tell me in detail about setting up bluetooth device and phone.
Yes u can perform backuping and sending sms with this software as discussed above.
I have posted before that i am unable to detect my phone 6275 using this software.
Version of SMScaster i am using is 2.8 registered.
Plz help me in solving out my problem.
can u plz also tell me how to use it via bluetooth.
@Vishal
Sent SMS also
Hi Vijay,
I am unable to take the back up of sent & draft items. please help me & lemme knw the version you are using...
Nothing perfect!! regardless of brand. Wantedly they leave such flaws... looks like they don't want users to be satisfied and stick one handset for long.
