satishdave
Using Ppc 6700 For First Time
Hi
I got a PPC 6700 installed with ROM 3.50.00 WWE dt.04.25.07 Radio version 1.43.00 from one of our friends
I am new to this PPC, also googled about PPC s for installing the applications & related stuff
some way I was able to setup OUTLOOK sync on device working fine, still have few issues
please inform me where can I find basic information ( start up) on how to install applications, about Hacks.
I have few issues with my ppc which i want to resolve
1.want to change the service Provider name appearing on todays Home screen & other links like phone dialer, on the WL manager
(some other persons name is appearing here)
2. I am not able to connect my office wi-fi.
I've latest NetGear Wireless Router cum Access Point. It is set with following options:
Security: NONE
Authentication Type: Open
Other laptops & systems in the network are easily able to connect to this Access Point. While my PPC-6700 can not associate itself.
I have configured the IP, Subnet, Default Gateway,& DNS 1 & 2 as they are configured in my Wireless router on my ppcs tiacxwln Compatible Wireless Ethernet adapter settings, , I am able to see the WIFI strength indicator & My WIFI name on my PPC when WIFI is turned on but unable to browse on the Explorer, however using *777, I am able to browse but I prefer to use WIFI in office Priemisis
also hint me on point 1 discussed above
Please Help!!
Edited by satishdave
I just purchased this phone 6700 & is my first PDA, so I'm quite unfamiliar with PDAs. I also would like to make this WIFI working, Previous owner said that the wifi already worked with hime ( he was using D-link wireless router)
I've NetGear Wireless Router WGR614 v7. It is set with following options:
Security : NONE
Authentication Type : Open
Other laptops & systems in the network are easily able to connect to this Point. While my PPC-6700 can not associate itself.
I have configured the IP, Subnet, Default Gateway,& DNS 1 & 2 as they are configured in my Wireless router on to my ppcs tiacxwln Compatible Wireless Ethernet adapter settings, I am able to see the WIFI strength indicator & My WIFI's SSID name on my PPC, when WIFI on phone is turned on but unable to browse on the Explorer,
However using *777, I am able to browse but I prefer to use WIFI in office Priemisis
I have configured the other options on the Wlan & wifi settings on phone but still its the same,
Please help me connect to wifi,
Go to Settings-Connections-then choose wi-Fi
Choose Add new,
Then enter Network Name, Conncets to-The internet,
then enter authentication type - whether WPA-PSK or WPA ( I Chose WPA-PSK)
Enter Data Encryption (usually TKIP)
then enter your Netywork Key (or password)
Then try and connect, that should do the trick.
Choose Add new,
Thankyou for your reply to my post!
Finally the wifi is connected. after trying a lot. I had hard reset the device and put in the Network key password ( WEP) that's it ! ( i didnt even put in the IP & other stuff but it had dected & got connected .Good, think there would have been some registry error unidentified pror to the hard reset
Thankyou all guys for your support. I am posting from my ppc -wifi, thanks once again!! :yes:
