saurabh2.kumar
How Can I Check That My Nokia 2112 Is Compatible For Ruim
Pls let me know how can i chech that my nokia 2112 cdma phone is compatible for using RUIM.
I am using the traditionally programmed handset.
A slot is present in my handset but I am unable to figure ot that the same will work.
Pls help
Pls help
try inserting a RUIM card from somebody and using the handset after that.
Till you dont reflash your phone with RUIM firmware your phone can never support RUIM.
Can u please explain the procedure to flash with RUIM firmware. I have the diego software but i dont have the flash files.
Pls help
Diego can not flash phone. Flashing is possible only with special hardwares. You can go to mobile repairer who flashes nokia. They can do it for u. If they refuses to do, you can ask them if they will do it if you take flash files along.
