ravjeet 3 Report post Posted February 15, 2008 (edited) Procedure to convert ppc6800 to ruim . 1)remove back cover (4 screws) remove the thin sheet metal plate stuck on the pcb. 2) will see six points on the pcb . 3) solder sim tray on these points see direction of ruim card photo att . Remember we require the sim tray as per pin config att 4)solder jumpers as per photo att 5)cut the sheet metal sheet as to accommodate the sim tray. 6)as we have put the sim tray the original battery will not fit find extended battery cover and use it with standard battery . 7)upgrade radio to 1.47.01 .might have to unlock the pda to upgrade radio . Procedure can be found on net as titan unlocker. 8) in qpst change config to ruim if available can be done with cdma workshop free version also. Phone is ready for reliance service use photos.zip Edited March 15, 2008 by ravjeet Share this post Link to post Share on other sites
Nirvana 4 Report post Posted February 15, 2008 Fantastic!!! Thanks a lot for sharing this... have to get a PPC6800 soon Share this post Link to post Share on other sites
adisa 0 Report post Posted February 15, 2008 great job ravjeet. Share this post Link to post Share on other sites
ssr 10 Report post Posted February 16, 2008 Finally wait is over Gr8 work ravjeet and adisa by theway what is the backup capacity of dopod with this mobile. Which version of mobile u have Sprint or versizon? Share this post Link to post Share on other sites
ravjeet 3 Report post Posted February 16, 2008 check link below for battery spec it is 1500mah same as ppc6800 original. there are some 1600mah battery also available of the same size for d810/htc3600. modification can be done on any 6800 i have done it on sprint. http://www.easy-battery.com/pda-battery/dopod-trin160.php ss_rakesh said: Finally wait is over Gr8 work ravjeet and adisa by theway what is the backup capacity of dopod with this mobile. Which version of mobile u have Sprint or versizon? Share this post Link to post Share on other sites
kshah 452 Report post Posted February 16, 2008 This is really a great job. Hats off to ravajeet and adisa. Share this post Link to post Share on other sites
ssr 10 Report post Posted February 16, 2008 ravjeet said: check link below for battery spec it is 1500mah same as ppc6800 original.there are some 1600mah battery also available of the same size for d810/htc3600. modification can be done on any 6800 i have done it on sprint. http://www.easy-battery.com/pda-battery/dopod-trin160.php That's a clever workaround Now I have wait for my PPC Share this post Link to post Share on other sites
vishalkumar 0 Report post Posted February 16, 2008 Fantastic job guys. Thanks a lot. Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 16, 2008 Rather then Going for LiION Battery Get any LiPolu Batteries for Replacements LiPoly is could be more thin and we can cut the Cover Plastic easily Share this post Link to post Share on other sites
@mitJ@in 256 Report post Posted February 16, 2008 from where i can get a htc 6800? and what is the price of htc 6800? Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 16, 2008 BAD ESN Phones can be baught from Ebay.com @ $220 Share this post Link to post Share on other sites
satishdave 2 Report post Posted February 16, 2008 Great job Ravjeet ! & thanks a lot for your help on yesterdays Work, configuring my phone! Share this post Link to post Share on other sites
Honest 836 Report post Posted February 16, 2008 ^^^ Welldone my dear Ravjeet. Hats off to you. Regards. Share this post Link to post Share on other sites
ssr 10 Report post Posted February 17, 2008 (edited) hetaldp said: Rather then Going for LiION Battery Get any LiPolu Batteries for Replacements LiPoly is could be more thin and we can cut the Cover Plastic easily Do u mean back cover(which covers battary) of 6800? Is it not possible to get a remolded back cover of PPC accomidating RUIM slot? Edited February 17, 2008 by ss_rakesh Share this post Link to post Share on other sites
kshah 452 Report post Posted February 17, 2008 (edited) ss_rakesh said: hetaldp said: Rather then Going for LiION Battery Get any LiPolu Batteries for Replacements LiPoly is could be more thin and we can cut the Cover Plastic easily Do u mean back cover(which covers battary) of 6800? Is it not possible to get a remolded back cover of PPC accomidating RUIM slot? I think if one goes to FRP molder, he can mold FRP covers. Fiber Reinforced Plastics can me made in any color, with very high gloss. (Helmets are made from FRP). Making wood mold may cost less than 750 buck. I will suggest RIMWEBIANS who are interested in buying 6800 from US, ontribute some money to person who has 6800 and he can get covers made and then gives covers at cost or add little profits to cover his out of pocket expenses. Covers can be as thin as 1.5 mm Edited February 17, 2008 by kshah Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 17, 2008 LiION Battery Contains Cell with Liquid so to Protect it a Hard Metal Cell is Needed but in LiPoly which only have High Quality Polymer dont need Metal Casing so it will be more Thin and its Cell can be Unassembled from to Better accommodate into PPC6800 Kalpak Idea to Rather go for New Back Cover is Best I have PPC6700 with Extended 2100 mah Battery which have 2x Thick Battery with Customised Back Cover so With in Next 2 Month we will see Extended Battery for 6800 with Extended Battery Cover also. Share this post Link to post Share on other sites
ssr 10 Report post Posted February 17, 2008 (edited) Yes, I prefer spending money on molded cover insted of disturbing battery. Also I am not sure, rather using battery sujjested by ravjeet, If I try to use standard battery for 6800 with molded backcover, Since from the design of 6800, there is no space b/w battery and board. Does battery sit properly over the board contacts, after soldering RUIM slot?. If this no prob then it is gr8. Sideo already has std and extd Lipoly batteries for 6800. http://www.seidioonline.com/index.asp?Page...&ProdID=814 http://www.seidioonline.com/index.asp?Page...&ProdID=888 Edited February 17, 2008 by ss_rakesh Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 17, 2008 (edited) http://www.seidioonline.com/index.asp?Page...&ProdID=797 http://www.seidioonline.com/index.asp?Page...&ProdID=827 We can use Hard Case Compatible for Slidding then we could Remove Original Cover which will allow use to use SIM / RUIM This is an Interim Idea !!! Untill we get Compatible Battery or Back Cover Edited February 17, 2008 by hetaldp Share this post Link to post Share on other sites
harismahesh 55 Report post Posted February 17, 2008 Its really a happy news that we can use PPC 6800 with Reliance which RUIM enabled. So now whose gonna take the authority to import to India and make it RUIM enabled and seel it...... Sadik bhai... come on... U cant sit idle.... sadik bhai and hetal has to do something to help us......... make its fast.... make it available for common man like us.. Share this post Link to post Share on other sites
ssr 10 Report post Posted February 18, 2008 If some one donot want to get a cover remolded I beleave they can buy for a cover for extended battery, Solder the RUIM & use the standard battery with some cushioning. Too many ways , waiting to hear if someone else converted their 6800 to RUIM Share this post Link to post Share on other sites
adisa 0 Report post Posted February 19, 2008 hetaldp said: http://www.seidioonline.com/index.asp?Page...&ProdID=797http://www.seidioonline.com/index.asp?Page...&ProdID=827 We can use Hard Case Compatible for Slidding then we could Remove Original Cover which will allow use to use SIM / RUIM This is an Interim Idea !!! Untill we get Compatible Battery or Back Cover look my attach ! New_Folder.rar Share this post Link to post Share on other sites
sutarianiral 1 Report post Posted February 21, 2008 wow ! a breakthrough achievement. .. im waiting for some one to do the importing,programing,soldering stuff and make it ready to use with just inserting an ruim card left . guys who are thorough with the things can have some deals over here and ultimately help everyone to get the phone .! cos not everyone are goin to do the things of soldering n programing. Share this post Link to post Share on other sites
gauravjc 47 Report post Posted February 21, 2008 @Niral Sutaria Work is still half done Ravjeet and other co members are still working on the battery issues !! Lets hope some solution comes up soon ... !! Share this post Link to post Share on other sites
adisa 0 Report post Posted February 22, 2008 @gauravjc i love you....... Share this post Link to post Share on other sites
gauravjc 47 Report post Posted February 22, 2008 @adisa Thanks buddy !! but may i know why do u love me ? Share this post Link to post Share on other sites
