Vishal Gupta
Uploading More Than 3 Ringtones
hi guys
i want to know what will happen if i add more than 3 rt using bitpim in my LG-RD2030
because it allows only 3 rt and i want to add more than it
did anyone check it?
please guys tell me?
hi guys
:clap:
ive lost count of how many times ive answered that question.
there's no use in uploading more than 3 ringtones.
bcauz although there is space for more than three (i mean in the mildl folder),
the phone's operating system does not have a memory slot to load them.
it cannot handle more than 3 custom made ringtones.
and if i add more than 3 what will happen
i mean if the mobile will not start or any other?
Yeah - I have already tried with 7130 - it too allows only 3 :(
U can upload - nothing happens but the phone's OS doesn't recognise it.
That is because the index of ringtones(not accesible from bitpim) has only 68 (or somethin - i don't remember entries) and anything beyond is not indexed - so not recognised. I really think they should have allowed more - provided a sortinfo kind of file like they did for wallpaers (on 7130) - I have uploaded 8 wallpapers and all are showing up :)
hey guys, does this mean we could add more wallpapers than that provided by reliance? are the extra wallpapers added in the sequential order, ie, icon04.dat, icon05.dat...?
Hi Bored I think what U R referring is for 2030 only. In 7130 the moment I update the rt it plays the new one. Only the header file content will show up properly after reboot. I think it is loaded in the RAM and to reload from the embedded file system U need to Reboot.
There may/should be a refresh command too which we don't know.
karpar - I was reffering to 7130 (LG color) wallpapers don't know about 2030 _ I don't think it will show up more than 3 as a friend of mine had said.
whoa bored, now i dont know whether to call this a security issue or a rib-tickling joke...
but i sure hope you would continue...at least using the forums.
thanx for the clarification code. good i had the time to show off only to my cousin...!
Edited by karpar
I believe there are only 3 re-Writable memory slots. That's why you can't upload more than three. If you could do that, the maker of the handset would have said it in the specification :) to ask more price for the same handset. re-writable memory is too expensive to hide. Isn't it :grin:
Edited by turbasu
