Vishal Gupta
Combining Two Ringtones
hi guys
is it possible to combine 2 rt to make a single rt with the help of PSMplayer or any other s/w
i mean i like 2 rt very much
and i want that both shoul play when any call is received.
so i want to combine both to make a single.
is there any way?
like by cutting both by half and merge them using any s/w if available.
please tell.
U can try Anvil studio to Edit Midi Files.
There are many advanced softwareau can get to do this if U search Google but mostly shareware and needs some indepth knowledge of midi which atleats I don't have. Good lyuck
There are many advanced softwareau can get to do this......
Try soung forge.... or drumbeats..... these are very good for looping, adding instruments etc....
:ph34r::):( ooo i think that i got his question wrong,
i tht that he wants to combine two ringtones into 1, not that he wants to join 2 MIDI files and then convert it to ringtones,
cauz that's whats' written there.
oops,so sorry
it is possile with quick time in fact i had tried it look for in ringtones section i had combined chalte chalte mi2 and one other
just have a look :)
shabbooo, post your ringtone so we can check it out...
i tried mi2, but i couldnt get a decently tweaked version, i tried doing it myself and it came out well in psmplayer, but in the phone it was awful...why such a difference?
and is it possible for anyone to develop a software that gives an output as that of say, 2030 for instance.(i know im being selfish!) so that it is easy for us to decide which tone sounds good before we upload it...
static, the simplest way i believe to join two ringtones would be to join the two midi files that were already created and cut the gap out...
It can be done in two ways.
One is if u wanna add a particular instrument to play simultaneously with another rt. That's called LAYERING.
The other is if you want the reduce ur rt by half to accommodate another rt in the following half of the sound scale.
There are lots of s/w but u need good knowledge of multimedia apps to do that.
