sush
Does R Connect(net) Work Fine With 2130
Hi All
Can any one pls tell if R-connect works well with LG 2130 .
I already have a USB cable wich i used with LG 2030. Can i use the same
Ya i purchased the RD2030 cable and used that itself from the local market
and daily am using R-connect :)
The connectivity and speed depends on the netwrk strength of your area, and not on the handset. All are equally good.
