stanner_austin
Ppc 6700 Network Problem
hello.
hope any one help me out.
i am not much expert.. but good in HTC so i want to solve this one also.
i am good in Nokia sagem Motorola Samsung lg china and as i say before HTC and Iphones many many more..
i have ppc 6700 network searching.
i used code to rewrite reliance prl of any lg model i know all rel prl will be same.
writed ok still network searching.
i am using phone with RUIM card.
i see phone esn is 000000000 is this case of no network???
and as i see in phone some one tryed to unlock extended rom all contact from there is deleted.
i can see only autorun.exe
seems when i click on it its show error probably not find files that's why.
i see its write reliance mobile world.cab and some customization files.
so any way to solve this network searching problem???
its possible because of extended rom not able to install data in phone so not getting network??
or i have to write special prl for this model?if anyone have upload it here or pm me i give you email address of my.
or this phone have hardware problem?
hope any one can give me solution & answers..
@hetal patel
can you give some advice if no one is able to do??
BR
Chevli
Edited by stanner_austin
Hi !
External Rom has nothing to do with searching of network !
Radio is all about related to network, wot is the version of Radio Rom you have been using ?
Have you check the soldered Ruim Socket if its in right place with good connection to the board ?
I believe its problem with the sim tray fitting kindly check for the same again and it should solve the problem !
Hi !
ditto
If you keep ESN as 00000000 it will not catch the Network as ESN Checksum can not be made
Feed the some Valid ESN and with its Checksum, also make RUIM mode enabled then Restart the Phone and Try, Try to Flash Latest Radio ROM into Device also.
In which Country U R, Depending upon that Try to load Appropriate PRL (Preferred Roaming List)
Edited by hetaldp
Good info, i never knew this.
If you Keep RUIM Mode and if there Problem in RUIM or RUIM tray again ESN can fall back to 00000000 Try to keep mode
RUIM if Avail in QPST and check which ESN it is taking is taking it from RUIM then no problem and if its again taking ESN of NVM then you have to lookout for the problem in RUIM things.
