varghese.cherian 0 Report post Posted February 22, 2008 I have a MG 880 that I recently got from my office. I installed it and the installation went smoothly. I am able to make voice calls and to send SMS. But the moment I try connecting to the Internet I find that the connectiong goes through and the internet is connected but within 4-5 seconds, the connection fails and it re-connects. This happens continuously. I do not get any error message. (I was able to query the modem and it shows success on some fields and error +CME Error : 3) on other fields. What can be the possibility and how do I solve this problem? Share this post Link to post Share on other sites
mozilla 0 Report post Posted February 22, 2008 (edited) I have a MG 880 that I recently got from my office. I installed it and the installation went smoothly. I am able to make voice calls and to send SMS. But the moment I try connecting to the Internet I find that the connectiong goes through and the internet is connected but within 4-5 seconds, the connection fails and it re-connects. This happens continuously. I do not get any error message. (I was able to query the modem and it shows success on some fields and error +CME Error : 3) on other fields.What can be the possibility and how do I solve this problem? Friend, have u checked whether ur pc is infected by virus/spyware which blocks ur net? and wats the signal strength in ur location? Edited February 22, 2008 by mozilla Share this post Link to post Share on other sites
Arun 795 Report post Posted February 22, 2008 Can you try connecting using a Dial-Up-Networking dialer instead of the default R-Connect dialer? Share this post Link to post Share on other sites
suvirajshetty 4 Report post Posted March 5, 2008 please go the setting option of the netconnect dialer and check whether you have entered your username and password i.e your connection number ..please check Share this post Link to post Share on other sites
