suvirajshetty 4 Report post Posted February 22, 2008 can any give information whether prepaid customer with lifetime validity can surf through rconnect Share this post Link to post Share on other sites
spknair 1 Report post Posted February 22, 2008 If you purchase datacard you can use @0.6/peak 0.3/ ofpeak but BSNL gives unlimited net through CDMA1x with 144 kbps at 250.00 permonth & broadband at 550.00 PM Share this post Link to post Share on other sites
copperco2 24 Report post Posted February 22, 2008 If you purchase datacard you can use @0.6/peak 0.3/ ofpeakbut BSNL gives unlimited net through CDMA1x with 144 kbps at 250.00 permonth & broadband at 550.00 PM you are very lucky guys compared to us... we dnt have an ultimate option to go for a broadband service.. Share this post Link to post Share on other sites
Honest 836 Report post Posted February 22, 2008 ^^^ @suviraj Yes my dear friend, prepaid lifetime validity customers can also use the netconnect facility at the following charges : Peak Hours : 0.60 paise per minute Off-Peak Hours : 0.30 paise per minute Regards. Share this post Link to post Share on other sites
suvirajshetty 4 Report post Posted February 27, 2008 (edited) ^^^@suviraj Yes my dear friend, prepaid lifetime validity customers can also use the netconnect facility at the following charges : Peak Hours : 0.60 paise per minute Off-Peak Hours : 0.30 paise per minute Regards. thanks buddy for information i own a lg rd 2130 with prepaid connection..i dont have lifetime validity..but since i bought usb modem i want my phone no to be converted into lifetime validity or recharge with 404 with 1 yr validity bcoz i dont want to spend much on my phone bills please advice Edited February 27, 2008 by suvirajshetty Share this post Link to post Share on other sites
Honest 836 Report post Posted February 27, 2008 ^^^ @suviraj Yes my dear friend, just go for Lifetime scheme for your prepaid mobile. It will be the best option for you. Regards. Share this post Link to post Share on other sites
suvirajshetty 4 Report post Posted February 28, 2008 hi there..thanks again for promt reply but is there any service issues with life time validity..will rim guys entertain my problem in future..and last but not the least can i convert my lifetime to normal recharge or postpaid bye Share this post Link to post Share on other sites
Honest 836 Report post Posted February 28, 2008 ^^^ @suviraj My dear friend, their is no service issue with life time validity. Yes RIM guys definetely will entertain your problems in the future. And you can convert your lifetime to normal recharge or postpaid later also. Regards. Share this post Link to post Share on other sites
suvirajshetty 4 Report post Posted February 29, 2008 ^^^@suviraj My dear friend, their is no service issue with life time validity. Yes RIM guys definetely will entertain your problems in the future. And you can convert your lifetime to normal recharge or postpaid later also. Regards. thanks a lot Share this post Link to post Share on other sites
