drali
Help Me In Writing A Cd
I wanna play mp3 songs acc to my choice(sequences 1 2 3...).I am writing rewritable Cd using XP CD writing wizards(No success).Shud I use Nero Or I have to edit d tags of each songs?
Thanks.
just rename the songs by giving them numbers as you would like to play. For example:-
1(songname)
2(songname)
3(songname)
and so on
and write these files to Cd and they will play in the order you have given numbers.
Edited by vishal
u can also try it by making a playlist according to your sequence on winamp, save that playlist & burn it on the cd along with the tracks.
Instead of XP CD wizards, etc, why not just try WMP? WMP 11 (not sure about earlier versions) makes a WPL playlist by default. You can get it to make an M3U instead. You could choose fromt he playlist how you want the songs to be played.
Overall, I dont like Winamp... but thats my personal feeling...
You can rename/number the songs as Vishal said, but then with that method you wont be able to change the playing order later, if you wish to. However, I guess you would be still able to do it, if you make a playlist of those files later...
@drali
MY dear friend, instead of using the series :
1 (Song name)
2 (Song name)
3 (Song name)
try using
001 (Song name)
002 (Song name)
003 (Song name)
Because if you use simple series 1 2 3 then your 10th song will be placed even before the 1st song.
Thank you all. Now i can do it by these tricks.
