Greets all,
Just got my Treo 500v few days ago and like all savy new owners I'm scouting net for software. It's a Spain's model.
I found a bunch of it for wm6 but in 99% of the time I can't install the software - it fails with the reason "Not intended for this device" or when it does install I get "can't find components".
I presume this has something to do with rights to install programs.
If anyone has ANY idea on how to actually determine what WM6 supported programs are compatible with WM6 software ( :eek: ) or hot to install it I would really appreciate it.
Does it have something to do with the fact that it is still locked? Should I somwewhere (and tell me where please!) get ROM imge and reflash it? I am out of my wits here!
Thanks.
its a palm device, you can not install WM software. Palm program has extension of .prc
If you are looking for palm software, go to palm ware sites and download.
kalpak...
500v is windows mobile based...
sorry, I thought it is centro's european number. I am really sorry for misguiding. 'coz I was misguided. :NOTriste:
ahhh... but its strange how he cant install anything... maybe the rom is locked
WM6 has some certificate (security) issues like VISTA as I know.
Well I found out - it is a smartphone with WM6 (it has no stylus or touchscreen) - once I figured that out I have no problems anymore.
But it+s nice to know that it favors Smarthone software over the WM6 (evethough it IS WM6 powered).
I hope someone will find this info usefull.
