sampat
Uim
LG rd 3100 -Phone Book ----> names provides one facility " Copy to UIM" and " Move to UIM "
What is meant by UIM ? What is this facilty and How it helps ?
RUim is the Sim card which is there in the phone (just like the sim card in GSM phone). The above option allows you to move the numbers from phone memory to RUIM, so that, you dont have to enter the numbers again, if you are using another handset (which ofcourse should be RUim enabled).
:winko:
:winko:
:GirandoOjos: Thanks
