PLS 0 Report post Posted March 13, 2008 HI All Rimweb Guru, I am planning to use my CDMA Htc touch bought in USA with either relaince or TATA, so need you valuable help in understanding floowing things.As per Hetal guru's research I guess we can use it on Tata. 1) Is any one able to use Wap from the handset 2) Can we use full internet from the handset itself by using QNC (quick connect) on tata or RIM ustar handset 6700 using #777. 3) is there any other procedure through which we can use full internet not just wap from the handset itself, like push email or skype like tools Thanks PL Sharma Share this post Link to post Share on other sites
vikasmahajanz 33 Report post Posted March 13, 2008 HI All Rimweb Guru,I am planning to use my CDMA Htc touch bought in USA with either relaince or TATA, so need you valuable help in understanding floowing things.As per Hetal guru's research I guess we can use it on Tata. 1) Is any one able to use Wap from the handset 2) Can we use full internet from the handset itself by using QNC (quick connect) on tata or RIM ustar handset 6700 using #777. 3) is there any other procedure through which we can use full internet not just wap from the handset itself, like push email or skype like tools Thanks PL Sharma Well u can use miniopera software.. and access any type of sites.... You can download it from http://www.operamini.com/ Share this post Link to post Share on other sites
drmadhu 87 Report post Posted March 13, 2008 HI All Rimweb Guru,I am planning to use my CDMA Htc touch bought in USA with either relaince or TATA, so need you valuable help in understanding floowing things.As per Hetal guru's research I guess we can use it on Tata. 1) Is any one able to use Wap from the handset 2) Can we use full internet from the handset itself by using QNC (quick connect) on tata or RIM ustar handset 6700 using #777. 3) is there any other procedure through which we can use full internet not just wap from the handset itself, like push email or skype like tools Thanks PL Sharma i am like to buy htc touch where are u get from please give me suggesion Share this post Link to post Share on other sites
