savramesh 37 Report post Posted March 17, 2008 Nokia 6265 features posted in nokia website says nokia 6265 has the following options Options for brightness adjustments, white balance settings and Funframes http://www.nokia.co.in/A4534133 But my nokia 6265 does not have this option under camera settings. I have only option night mode, quality and self timer. Do anyone have this option in your 6265 ? Share this post Link to post Share on other sites
vishalkumar 0 Report post Posted March 17, 2008 ^^^ You are right Ramesh. I noticed that these options are missing in my cell too. Wonder what is the reason? Share this post Link to post Share on other sites
savramesh 37 Report post Posted March 17, 2008 well lets mail nokia about this and ask them for an upgrade. lets keep raising issues with 6265 to nokia care and that may result in nokia providing an upgrade. all the best Share this post Link to post Share on other sites
vishalkumar 0 Report post Posted March 17, 2008 ^^^ That's true, but they should atleast provide what they are advertising on the site. Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted March 17, 2008 @savramesh, If what you are looking for is fun images, then you can open any photo you have taken with the 6265, select options and then edit image. Here you have many options - you can select and do whatever you want here. Enjoyyyyyyyyyyyyyyyyyy Share this post Link to post Share on other sites
savramesh 37 Report post Posted March 17, 2008 after taking a photo and if u edit photo u have only the following options Insert Text Insert Clip-art Insert image Crop Image But i am talking about the options like brightness adjustments, white balance settings and Funframes which are used while taking a photo and not after taking photo. Share this post Link to post Share on other sites
KumaarShah 143 Report post Posted March 18, 2008 ^^^ You are right about the above options. However if you use lip-art, you get something sort of funframes (I also agree it is not on par with the ones in other phones) As for the other features, they are not available on 6265 and you cannot do anything about it. Even if all of us 6265 and 6275 and 2865 etc users jointly approach Nokia, they will just not do anything to help us out. Why the very basic lock feature which is a standard feature on all S40 phones is not available with Nokia CDMA phones. Any idea whether these features are not available only in India or even elsewhere? If these features are not available anywhere, it is Nokia which is the culprit. If only in India, then the operators - RCOM, TATAs are jointly culprits with Nokia. Share this post Link to post Share on other sites
vishalkumar 0 Report post Posted March 18, 2008 ^^^ Yes, but in any case, it is the user who has to suffer. Share this post Link to post Share on other sites
