savramesh
Not Able To Format Memory Card
I am able to read and use files in my 6265 minisd memory card. but i am not able to save any files to memory card. also not able to format memory card.
getting error - 'Operation Failed'.
i reinstalled software of nokia 6265 today, but the problem is not solved.
any suggestions? i have planned to visit nokia care again tomorrow.
are u able to format or write on memory card through a pc or laptop ??
PC also not able to write or format
Which memory card are you using and its size. Coz with Kingston Mem card, 1GB I faced the similar problem so now changed to 2GB Kingston. I am using the mem card reader since Nokia 6265 supports only till 1GB but can use it till 2GB card. That 1GB card was useless then.
Now, I can read / write to mem card (2GB Kingston) via bluetooth / infrared but not thru datacable instead I am using mem card reader.
--Mohu
Hi
u 2 Try memory card reader once then see what type of result u will get !
i think u will get +ve response if u use card reader !
Regards
Shyam
Some memory cards have a write protect switch. Check whether it is there and turned off :)
i visited nokia care today and got to know that the problem is with phone strip connecting upper and lower slides of phone.
i recently changed the strip (3 months back) for around 1.5k and now again it got damaged.
strip problem is common with sliding phones and it is very common with 6265.
this is the 3rd time my phone strip is getting damaged. i used to handle smoothly still its eating my head.
the problems i faced till date with 6265 (16000 INR mobile)
1. strip problem within 1 month of purchase 1.8 years back (got repaired free of cost meeting warranty)
2. speaker problem 8 months back (800 INR for changing speaker kit)
3. strip problem 3 months back (1500 INR)
4. again now strip problem
5. panel is broken and i am not getting a panel for 6265, its very very very rare to get. at last through one shop i have ordered first quality panel (450 INR).
all together i have spent 18750 INR till date and dont know how much more it will eat in future. but still i am proud 6265 user. what else to do.
enjoy........
enjoy........
b4 u spent lot's of money ! buy 6275 ! Best Option to 6265
Regards
Shyam
