jasprit
Nokia 2112 - Rconnect
I am using a Nokia 2112 Handset...i am not able to connect to Rconnect as it gets hanged at the time when you hit connect or it throws an error that port is already in use.....i've re-installed rconnect twice...
kindly suggest somthing as i am facing the problem for quite a long time
Regards,
Jas
