tanveer 59 Report post Posted July 10, 2004 Is there any way i can modify the WORD option of typing the message, I mean it does not have any flexibilty. There is a section on this forum that discussed ways to modify T9 dictionary for LG handset, is there any way of modifying the WORD dictionary for GTRAN? Share this post Link to post Share on other sites
rakesh5295 0 Report post Posted July 10, 2004 can any one give me the link to that discussion where it is discussed how to modify t9 dictinary for lg handset. Share this post Link to post Share on other sites
Mahidhar 3 Report post Posted July 10, 2004 Foe the LG handset, T9 Help follow this link and u'll have your doubts cleared ... Share this post Link to post Share on other sites
tanveer 59 Report post Posted July 10, 2004 any suggestions from the patron of this thread, GTRAN ROCKS Share this post Link to post Share on other sites
gtran_rocks 0 Report post Posted July 10, 2004 As of now, the WORD feature of GTRAN is non-customisable tanveer. Infact your post drew my attention towards this problem. I tweaked with my phone for long but couldnt find any way out. So I visited GTRAN's korean website and logged in the query in the Q/A section. Will post the reply as soon as I get one from them Share this post Link to post Share on other sites
gtran_rocks 0 Report post Posted July 10, 2004 This is the auto response from GTRAN website postmaster@fdknt003 to me More options 1:30am (37 minutes ago) This is an automatically generated Delivery Status Notification. Delivery to the following recipients failed. qna@gtran.co.kr Sad state of affairs at the official site - The communication interface bounces queries from customers Share this post Link to post Share on other sites
tanveer 59 Report post Posted July 11, 2004 and half the links of the indian site are down like the FAQ and the PC sync section. Hope someone comes up with a solution to this problem Share this post Link to post Share on other sites
RIM-MAN 0 Report post Posted July 15, 2004 As of now, the WORD feature of GTRAN is non-customisable tanveer. Infact your post drew my attention towards this problem. I tweaked with my phone for long but couldnt find any way out. So I visited GTRAN's korean website and logged in the query in the Q/A section. Will post the reply as soon as I get one from them It doesnt matter if its LG or GTRAN have you exactly followed the steps necessary to add a word you want in the dictionary, first enter the word in ABC format as soon as the cursor leaves the last letter moves onto the next space immediately cycle using your soft key 2 button to go back to T9En, next time you enter the word it will come up proper however there are instances when the word comes up jibberish after using the above mentioned steps but then all you need to do is press the next button and that will allow you to cycle through all the words with the exact same keystrokes as the word you have added. Let me know if this works for you, I might upgrade to a GTRAN soon Share this post Link to post Share on other sites
