shi_2000_21 1 Report post Posted April 15, 2008 Friends, I am going to buy some chinese CDMA handset for my tata indiacom connection. What specification I have to look so the handset works properly works with my tata connection. thanks Share this post Link to post Share on other sites
Dj 25 Report post Posted April 15, 2008 you might wanna check for cdma 1x operation & ruim/tsim support Share this post Link to post Share on other sites
Honest 836 Report post Posted April 15, 2008 ^^^ @Rajkumar MY dear friend, I think you have to go for Dual mode chinese handset which support both GSM as well as CDMA as their is no option for going with only CDMA in chinese handsets. They come in dual mode only GSM+CDMA. Although you can get only GSM single sim handset in chinese brands. But you won't get only CDMA. Regards. Share this post Link to post Share on other sites
