Bhavin Shah
Lg Chocolate To 6275
hey.. can anyone tell me how should i transfer my phone book from Lg chocolate to nokia 6275... except manual entry
^^^ Bhavin Shah !
Dude search for R-World Phone Book Upload ! then try to down load your entries from R-world !
Regards
Shyam
the theory of transfer phone book from lg to nokia is allready in this forum and the solution done by hetal bhai please search the hetalbhai topics
hey.. can u put up the link where hetal has given the details....
this solution give by arun not hetal bhai i have copy the formula of arunbhai
The process is as given below:
The data can be transferred from LG .csv files to Nokia phones by
Following these steps:
1. Copy the .csv file received from LG to the PC.
2. Make a new folder (eg. Test) in Contacts folder of Microsoft Outlook.
3. Now in Microsoft Outlook
Go to "File"
--> SELECT "Import & Export..."
--> select from the next menu "Import and Export from another file"
--> Click "Next"
--> Select from the next menu "Comma Seperated Values (windows)"
--> Click "Next"
--> Select "Browse" and browse the LG file from where the
data has to be copied.
--> Click "Next"
--> Select from the next menu the Test folder of Outlook
which was created earlier.
--> Click "Next"
--> From Next window using the "Map Custom Fields..." map the fields
(THIS CAN BE USED TO MAP CORRESPONDING FIELDS of CSV FILE TO BE
COPIED TO CORRESPONDING OUTLOOK FIELD).
--> Select "Finish".
--> Data will be copied to Microsoft Outlook in the "Test" folder.
PC SUITE DATA TRANSFER STEPS--
--> Now connect the phone using DKU-5 or CA-42 (for models like
2112, 6225, 3105, 3125 etc) OR DKU-2 (only for 6255 and 6235) to the PC.
--> Once the phone is connected to PC Suite the PC suite icon on the
Windows Taskbar turns blue-green from grey.
--> Now open PC Suite --> Select Synchronize Option from menu.
--> On next window click on "Settings" button. This will take you to
Create Settings Wizard of PC Suite
--> Next window shows default "Microsoft Outlook" application
selected.
Click on next.
--> Now check only "Contacts" Checkbox, and uncheck all other
options and click next.
--> On the next window click on "Select Folders" button and browse &
select the folder where we had copied contacts earlier (Test folder
created here as an example).
--> Now in the next window select "Finish", this will start the
Synchronization and contacts from selected folder of Outlook will be
copied to the Nokia Phone.
OPTIONAL-- Before clicking "Finish" there is one more option
--> "Advanced" which can be used to set the direction of synchronizing
data i.e. the data from Microsoft Outlook only can be copied to Phone or
vice-versa.)
@bhavin
you are wellcome
