hab
Can We Call Reliance Gsm From Rim Cdma Using Unlimited Reliance Std(only Reliance Phone)
i want to know wether we can call from reliance cdma network to reliance gsm free of charge using any booster packs.
The answer to your question is clear NO NO my dear friend. You can't use Rim CDMA to make unlimited calls to Rim GSM.
yes as kamal also posted a big NO
Yes, If u using postpaid 999/- plan u can call all Reliance SMART phone for free. ( Tested )
Is it really possible to make free std calls to reliance gsm network from plan 999/-
yes its true. I have tested it. please reconfirm it from reliance.adag ( Amit Jain )
Not to all RTL, MP, CHATTISGARH, BIHAR are free. Assam and Orissa are not free. Others not sure
Exaclty..P.K Daga is right.
Since the calls from Reliance FWP to RTL Bihar and MP is treated as offnet and all other calls to other areas RTL will be offnet.
Secondly, It from only FWP.
From Mobile its always offnet.
@Sadik, You can take Unlimted Plan 525 too. That doesnt make any difference. In 999 you have 550 TT and in 525 you have 0 TT.
Further FYI.
In 525 plan you can block the call to all other operators, so that only onnet calls will be made.
Edited by reliance.adag
Sadik its Confirmed its not possible to make free std calls to Reliance GSM
Further to your mail regarding Unlimited Onnet STD 999 plan, we would like to inform you that this pack is available with Reliance Hello Phone subscribers. The details for the same attached for your ready reference.
In continuation to your query, please note that it not possible to make free STD calls on Reliance GSM network by using Unlimited Onnet STD 999 plan.
The list of Reliance Communications outlets nearest to your locality is attached for your reference.
Hope you find the information useful and we look forward to an opportunity to assist you in future.
Yours sincerely,
Vaishali Kadam
Customer Care
Further FYI.
how can we block the calls to non RIM in 525 plan. is there any charges to use this facility
