kishorevl 1 Report post Posted April 30, 2008 I am getting almost double the battary backup for my Classic 731 by charging thorugh USB cable Share this post Link to post Share on other sites
Honest 836 Report post Posted April 30, 2008 ^^^ @Kishore My dear friend, it is not possible that you can get more battery backup by charging through USB cable. Actually the battery will charge as per its maximum limit. Either you charge the battery through normal adapter or you charge it through usb cable. It will be charged only upto its maximum level. Their is a chance that your normal adapter may be faulty. As it is not charging your battery upto the fullest. Thats why you seems to have been experiencing the enhanced battery performance after charging the battery through usb cable. Check your adapter please. Regards. Share this post Link to post Share on other sites
kishorevl 1 Report post Posted May 1, 2008 ^^^@Kishore My dear friend, it is not possible that you can get more battery backup by charging through USB cable. Actually the battery will charge as per its maximum limit. Either you charge the battery through normal adapter or you charge it through usb cable. It will be charged only upto its maximum level. Their is a chance that your normal adapter may be faulty. As it is not charging your battery upto the fullest. Thats why you seems to have been experiencing the enhanced battery performance after charging the battery through usb cable. Check your adapter please. Regards. It is not only my experience, my colleagues also tested and got the same result. I think the charges suppled by the company may not charge the battery fully. Share this post Link to post Share on other sites
commonman 228 Report post Posted May 1, 2008 It is not only my experience, my colleagues also tested and got the same result. I think the charges suppled by the company may not charge the battery fully. What else can you expect from "Classic" brand Share this post Link to post Share on other sites
Greatest 55 Report post Posted May 1, 2008 The brand Classic is owned by S.Korea major Telecom company, ZTE.... they are the ones who make phones for virtually anyone you can think off in the telecom world... the brand classic is targetted at low cost users.... i have been to their factory in Korea, and beleive me, they are a huge company comparable to Motorola, or sony ericcson for that matter...!! Just to let u know more, ZTE are the ones who manufactured the PCMCIA Cards for the reliance network!! Share this post Link to post Share on other sites
commonman 228 Report post Posted May 1, 2008 The brand Classic is owned by S.Korea major Telecom company, ZTE.... they are the ones who make phones for virtually anyone you can think off in the telecom world... the brand classic is targetted at low cost users.... i have been to their factory in Korea, and beleive me, they are a huge company comparable to Motorola, or sony ericcson for that matter...!! Just to let u know more, ZTE are the ones who manufactured the PCMCIA Cards for the reliance network!! For the record, as already discussed earlier in this forum, CLASSIC is owned by Reliance only. This brand is used by them for primarily chinese sets sources from multiple vendors. The manufacturer can be identified from the series used. 100 series is for JINPENG 200 for ZTE 300 HUAWEI 400 TCL 600 ROSE 700 KINPU further 01 to 30 is for B/W 31 to 60 is for COLOR 61 to 90 is for FM 91 to 99 is for camera So Classic 731 would be KINPU > COLOR Share this post Link to post Share on other sites
gupteswarsatapathy 0 Report post Posted May 1, 2008 (edited) Hi, Can some one tell me how is its battery life? How much time I can talk continuously in a full charge? Edited May 2, 2008 by Arun << Topic Merged >> Share this post Link to post Share on other sites
